System Status LEDs
System status LEDs are located on the front of the switch. The following table describes the colors and the states for the LEDs.
Callout LED Color/State Meaning
1 P1 Off PSU-1 does not have supply power.
Solid Green PSU-1 has power.
P2 Off PSU-2 does not have supply power.
Solid Green PSU-2 has power.
2 Alarm Off No alarm event has occured.
Solid Red Alarm event has occured.
4 System (SYS)
ISW 24GbP, 4-SFP only
Off System is not working or has no power.
Solid Green System is functioning normally.
Flashing Green System is booting, or database is saving or remote download is in-progress.
3
RR
(Ring Role)
Off Ring/Chain is secondary role.
Solid Green Ring or Chain enabled with Ring-Primary, Chain (Tail) or Balancing Chain (Central Block).
RS
(Ring Status)
Off No ring fail detected.
Solid Green Ring fail happened and was detected.
System Status LED locations
Locations of the system status LEDs
