Mount the Switch
Most ISW-Series switches can be DIN-rail mounted or wall-mounted. The ISW 24GbP, 4-SFP model switch can be rack-mounted in a two-post rack, but cannot be DIN-rail mounted or wall-mounted.
Mounting the ISW (DIN-Rail)
Mounting steps:
  1. Screw the DIN-Rail bracket on with the bracket and screws in the accessory kit.
  2. Hook the unit over the DIN rail.
  3. Push the bottom of the unit towards the DIN Rail until it snaps into place.
DIN-Rail Mounting
DIN-Rail Mounting
Mounting the ISW (Wall)
Attach the wall-mounting plates with the screws provided in the accessory kit.
Mounting the ISW (Two-Post Rack)
This procedure uses the two-post mounting kit. The ISW 24GbP, 4-SFP switch can be installed in a standard two-post equipment rack. It does not support Din-rail or wall-mount options.
Take care to load the rack so that it is not top-heavy. Start installing equipment at the bottom and work up.
  1. Attach a rack ear to one side of the switch, screwing it into the holes so that the flange (ear) is flush with the front of the switch.
  2. Attach the other rack ear to the other side.
  3. Attach the rack ears to the front rack posts, using the screws (rack post screws not provided).
