System Reset
The Reset button is provided to reboot the system without the need to remove power. Under normal circumstances, you will not have to use it. However, on rare occasions, the ISW-Series might not respond and you may need to push the Reset button.
Reset Button for the 8-port and 12-port Switches
Reset Button for the ISW 8GbP, 4-SFP+ Switch
Reset Button for the ISW 24GbP, 4-SFP Switch
