Reset Configuration Defaults via Web UI
If you want to reset the configuration to default, but keep management IP settings, do the following:
  1. Go to MaintenanceFactory Default and click Yes.
  2. Go to MaintenanceConfigurationSave startup-config and click Save Configuration.
    If you want to reset all configurations to the default:
  3. Go to MaintenanceConfigurationActivate.
  4. Select default-config and then click Activate Configuration.
  5. Change PC‘s IP address belong to 192.0.2.X networks.
  6. Change web‘s IP be 192.0.2.1 (default IP) to login DUT‘s Web UI.
  7. Go to MaintenanceConfigurationSave startup config and then click Save Configuration.
