8-port Switch Models
There are two 8-port switch models. The front panel of the ISW 4-10/100P, 2-10/100T, 2-SFP model switch includes:
The front panel of the ISW 4GbP, 2GbT, 2-SFP model switch includes:
8-Port PoE Series Front Panel
Front panel of the 8-Port PoE Series switches
1 = PoE LEDs 2 = System status LEDs
3 = Gigbit Ethernet copper ports 4 = Gigbit Ethernet SFP ports
5 = Device info/status 6 = Gigbit Ethernet SFP ports
The top panel of both of the switch models include:
Top panel for both 8- port switches
Top panel for both 8-port switches
1 = Dual power input (6p terminal block) 2 = RJ45 serial console port
3 = Reset 4 = Grounding lug
Both models support DIN-rail or wall-mount options. They are not rack-mountable units.
