Reset Configuration Defaults via CLI Command
If you want to reset the configuration to default, but keep management IP settings, do the following:
  1. Execute the command: reload defaults keep-ip
  2. Check interface and IP address, and confirm only management IP setting is kept.
  3. Execute the command: copy running-config startup-config
If you want to reset all configurations to the default:
  2. Check interface VLAN and IP address, and confirm they all change to default settings.
