Install Your Switch
Before you attempt to install or remove an ISW-Series switch, read the precautions in Safety Considerations for Installation.
The installation process includes the following tasks:
  1. Prepare to install the switch. See What You Will Need for the Installation.
  2. Install the switch. See Mount the Switch.
  3. Install one or two power supplies. See Connect Power Supplies, Alarm Relay, and Ground Connection.
  4. Power up the switch. See Turn on the Switch.
  5. Connect network interface cables. See Connect Network Interface Cables.
  6. Perform initial network connection and configuration. See Activate and Verify the Switch.
