28-port Switch Model
There is one 28-port switch model. The front panel of the ISW 24GbP, 4-SFP model switch includes:
This model does not support DIN-rail or wall-mount options. It is a 1RU rack-mountable unit.
ISW 24GbP, 4-SFP model 28-Port PoE Series Front Panel
Front panel of the ISW 24GbP, 4-SFP model 28-Port PoE Series switch
1 = USB Type A port 2 = 10/100/1000BASE-T OOB management port
3 = 10/100/1000Base-T PoE 802.3bt ports 4 = SFP+ ports (1/2.5/10G)
5 = Device info/status 6 = System status LEDs
7 = RJ-45 serial console port 8 = Reset
The rear panel of the ISW 24GbP, 4-SFP switch model includes:
ISW 24GbP, 4-SFP model 28-Port PoE Series Rear Panel
Rear panel of the ISW 24GbP, 4-SFP model 28-Port PoE Series switch
1 = Dual power input (4p terminal block) 2 = Grounding lug
