Activate IPv6 Address Family for a BGP Neighbor Using User Defined VRF
To configure multi-protocol BGP for exchanging IPv6 prefixes over IPv4 BGP Sessions for a BGP neighbor using an user defined VRF, do the following:
  1. Access global configuration mode.
     device# configure terminal
  2. Access BGP configuration mode.
    device(config)# router bgp
  3. Specify the autonomous system in which your device resides.
    device(config-bgp-router)# local-as 1000
  4. Navigate to the IPv4 Unicast Address Family context of the user defined VRF.
    device(config-bgp-router)# address-family ipv4 unicast vrf red
    device(config-bgp-ipv4u-vrf)#
  5. Specify the autonomous system in which the remote neighbor resides. Assign the remote AS to the neighbor.
    device(config-bgp-ipv4u-vrf)# neighbor 192.0.2.10 remote-as 1001
  6. Exit out of the IPv4 Address Family context.
    device(config-bgp-ipv4u-vrf)# exit
  7. Configure the IPv6 address family.
    device(config-bgp-router)# address-family ipv6 unicast vrf red
    device(config-bgp-ipv6u-vrf)#
  8. Activate the IPv6 Address Family for the BGP neighbor.
    device(config-bgp-ipv6u-vrf)# neighbor 192.0.2.10 activate
The following is a consolidation of tasks to perform to activate IPv6 address family for a BGP peer using user defined VRF.
router bgp
local-as 1000
