Do the following to configure the QoS for the tunnel. The same configuration can be used on both tunnel end points.
SLX# configure terminal SLX (config)#
device (config)# interface tunnel 22
device(config-intf-tunnel-20)# dscp 28
device(config-intf-tunnel-20)# ttl 135
device(config-intf-tunnel-20)# dscp-ttl-mode pipe
The default QoS mode is pipe.When the DSCP TTL mode is configured as pipe, the DSCP and TTL values that are configured on this tunnel interface are used.
When the DSCP TTL mode is configured as uniform, the DSCP and TTL values are copied from the packet being transported over the tunnel and is used in the tunnel header.
When the DSCP TTL mode is set to pipe and the DSCP and TTL values are not configured within the tunnel, the default DSCP and TTL values are used.
The following is the consolidation of the above configuration steps.
interface tunnel 20 mode gre ip source loopback 6 destination 32.32.32.1 router-interface ve 5 ttl 135 dscp 28 dscp-ttl-mode pipe
The following shows the configuration of a tunnel end point where the DSCP TTL mode is uniform. Here TTL and DSCP configurations are not required.
interface tunnel 20 mode gre ip source loopback 6 destination 32.32.32.1 router-interface ve 5 dscp-ttl-mode uniform
