device# show ip bgp neighbors
Total number of BGP Neighbors: 2
1 IP Address: 123.123.123.3, AS: 333 (EBGP), RouterID: 9.9.9.9, VRF: default-vrf
State: ESTABLISHED, Time: 0h1m32s, KeepAliveTime: 60, HoldTime: 180
KeepAliveTimer Expire in 17 seconds, HoldTimer Expire in 147 seconds
Minimal Route Advertisement Interval: 0 seconds
RefreshCapability: Received
Messages: Open Update KeepAlive Notification Refresh-Req
Sent : 2 15 3339 1 0
Received: 2 0 3356 0 0
Last Update Time: NLRI Withdraw NLRI Withdraw
Tx: 0h1m32s --- Rx: --- ---
Last Connection Reset Reason:User Reset Peer Session
Notification Sent: Cease/Administrative Reset
Notification Received: Unspecified
Neighbor NLRI Negotiation:
Peer configured for IPV4 unicast Routes
Neighbor ipv6 MPLS Label Capability Negotiation:
Neighbor AS4 Capability Negotiation:
Outbound Policy Group:
ID: 2, Use Count: 2
BFD:Disabled
Byte Sent: 146, Received: 0
Local host: 123.123.123.2, Local Port: 44575
Remote host: 123.123.123.3, Remote Port: 179
2 IP Address: 160.160.160.10, AS: 111 (EBGP), RouterID: 193.24.0.1, VRF: default-vrf
State: ESTABLISHED, Time: 0h1m33s, KeepAliveTime: 30, HoldTime: 90
KeepAliveTimer Expire in 12 seconds, HoldTimer Expire in 86 seconds
Sent : 8 0 553 5 0
Received: 8 9 498 0 0
Tx: --- --- Rx: 0h1m33s ---
ID: 2, Use Count: 2
BFD:Disabled
Byte Sent: 121, Received: 0
Local host: 160.160.160.20, Local Port: 53791
Remote host: 160.160.160.10, Remote Port: 179
device# show ip bgp neighbors 123.123.123.3 advertised-routes
There are 5 routes advertised to neighbor 123.123.123.3
Status A:AGGREGATE B:BEST b:NOT-INSTALLED-BEST E:EBGP I:IBGP L:LOCAL
Prefix Next Hop MED LocPrf Weight Status
1 110.110.110.0/24 123.123.123.2 0 0 BE
AS_PATH: 222 111
2 110.110.111.0/24 123.123.123.2 0 0 BE
AS_PATH: 222 111
3 110.110.112.0/24 123.123.123.2 0 0 BE
AS_PATH: 222 111
4 110.110.113.0/24 123.123.123.2 0 0 BE
AS_PATH: 222 111
5 110.110.114.0/24 123.123.123.2 0 0 BE
AS_PATH: 222 111
device# show ip bgp neighbors 123.123.123.3 last-packet-with-error Received Message Length: 45 BGP Message: 0xffffffff 0xffffffff 0xffffffff 0xffffffff 0x002d0104 0x014b00b4 0x09090909 0x10020601 0x04010000 0x01020202 0x00020280 0x00 BGP Header Marker: 0xffffffff 0xffffffff 0xffffffff 0xffffffff Message Length: (0x002d) 45 Message Type: (0x01) OPEN OPEN Message Version: (0x04) 4 AS Number: (0x014b) 331 Hold Time: (0x00b4) 180 BGP Identifier: (0x09090909) 9.9.9.9 Optional Parameter length: (0x10) 16 OPEN message optional parameters Parameter Type: (0x02) Capability Parameter Length: (0x06) 6 Capability Type: (0x01) MULTIPROTOCOL EXTENSIONS Capability Length: (0x04) 4 AFI: (0x0100) Unknown(256) Reserved: (0x00) 0 SAFI: (0x01) Unicast Parameter Type: (0x02) Capability Parameter Length: (0x02) 2 Capability Type: (0x02) ROUTE REFRESH(new) Capability Length: (0x00) 0 Parameter Type: (0x02) Capability Parameter Length: (0x02) 2 Capability Type: (0x80) ROUTE REFRESH(old) Capability Length: (0x00) 0
device# show ip bgp neighbors 160.160.160.10 received-routes
There are 5 received routes from neighbor 160.160.160.10
Status A:AGGREGATE B:BEST b:NOT-INSTALLED-BEST C:CONFED_EBGP D:DAMPED
E:EBGP H:HISTORY I:IBGP L:LOCAL M:MULTIPATH m:NOT-INSTALLED-MULTIPATH
S:SUPPRESSED F:FILTERED s:STALE
1 110.110.110.0/24 160.160.160.10 0 100 0 BE
AS_PATH: 111
2 110.110.111.0/24 160.160.160.10 0 100 0 BE
AS_PATH: 111
3 110.110.112.0/24 160.160.160.10 0 100 0 BE
AS_PATH: 111
4 110.110.113.0/24 160.160.160.10 0 100 0 BE
AS_PATH: 111
5 110.110.114.0/24 160.160.160.10 0 100 0 BE
AS_PATH: 111
device# show ip bgp neighbors 123.123.123.3 rib-out-routes
There are 5 RIB_out routes for neighbor 123.123.123.3
AS_PATH: 111
AS_PATH: 111
AS_PATH: 111
AS_PATH: 111
AS_PATH: 111
