With policy-based routing, you define a set of classifications that, when met, cause a packet to be forwarded to a predetermined next-hop interface. With this process, the packet bypasses the normal routing path in the routing table. If your policy has multiple next hops to a destination, packets are forwarded to the first available (UP) hop. If none of the next hops in the policy is available, then packets are forwarded according to the routing table.
| Route map | ACL | TCAM action |
Permit |
Permit |
The contents of the set command of the route-map entry are applied. |
Permit |
Deny |
The packet is passed and routed normally. The contents of the set command are not applied. A "permit" rule with no result actions is programmed in TCAM, which prevents further application of the route-map ACL. No ACL actions (except counter) are applied. |
Deny |
Permit |
The packet is passed and routed normally. No set commands follow the match command of a deny route-map stanza. A "permit" rule with no result actions is programmed in TCAM, which prevents further application of the route-map ACL. No ACL actions (except counter) are applied. |
Deny |
Deny |
No TCAM entry is programmed, therefore other route-map ACL entries are compared for a match. If no match is made, the packet is forwarded normally. |
If you do not specify an ACL in a stanza, normal routing occurs. The default ACL is not used.
| System Resource | Maximum amount |
| Configurable route maps | 200 |
| Configurable stanzas | 1024 |
| Available TCAMs | 2048 |
| Configurable next-hops in a stanza | 128 |
