Enter the
configure terminal command to access global configuration mode.
device# configure terminal
Enter the
router isis command to enter IS-IS router configuration mode and enable IS-IS on the device.
device(config)# router isis
Enter the
lsp-gen-interval command and specify a value to change the LSP generation interval.
device(config-isis-router)# lsp-gen-interval 60
The following example changes the LSP generation interval to 60 seconds.
