Activate IPv6 Address Family for a BGP Peer Group Using Default VRF
To configure multi-protocol BGP for exchanging IPv6 prefixes over IPv4 BGP Sessions for a BGP peer group using default VRF, do the following:
  1. Access global configuration mode.
     device# configure terminal
  2. Access BGP configuration mode.
    device(config)# router bgp
  3. Specify the autonomous system in which your device resides.
    device(config-bgp-router)# local-as 1000
  4. Enable exchanging IPv6 prefixes over IPv4 for BGP.
    device(config-bgp-router)# peer-group ipv6prefix-over-ipv4peer
    When the IPv6 address family is already activated under a peer-group and the command peer-group ipv6prefix-over-ipv4peer is executed, the Neighbor NLRI Negotiation capabilities are modified from IPv4 Unicast Routes to IPv4 and IPv6 Unicast Routes. This will reset the existing BGP IPv4 connections, those that are mapped to a peer-group and have IPv6 address family enabled.
    This reset also happens when IPv6 Address Family is already activated under a peer-group, and CLI peer-group ipv6prefix-over-ipv4peer is being disabled.
    This enables the exchanging of IPv6 addresses over IPv4 BGP sessions. This configuration only applies to those BGP neighbors who are members of a peer group.
  5. Navigate into the Peer Group context.
    device(config-bgp-router)# neighbor pgMain peer-group
    	%Warning: Please activate Peer-group for IPv6 address-family
  6. Specify the autonomous system in which the remote peer-group resides. Assign the remote AS to the peer-group.
    device(config-bgp-router)# neighbor pgMain remote-as 1001
  7. Assign the BGP neighbor to the Peer Group.
    device(config-bgp-router)# neighbor 192.0.2.10 peer-group pgMain
  8. Configure the IPv6 address family for the default VRF.
    device(config-bgp-router)# address-family ipv6 unicast
    device(config-bgp-ipv6u)#
  9. Activate the IPv6 Address Family for the peer group.
    device(config-bgp-ipv6u)# neighbor pgMain activate
The following is a consolidation of tasks to perform to activate IPv6 address family for a BGP peer using default VRF.
router bgp
local-as 1000
