device# show isis IS-IS Routing Protocol Operation State: Enabled IS-Type: Level-1-2 System Id: 768e.f805.5812 Manual area address(es): 11 Level-1-2 Database State: On Administrative Distance 115 Maximum Paths 8 Default redistribution metric 0 Default link metric for level-1 0 (conf)/ 10 (adv) Default link metric for level-2 0 (conf)/ 10 (adv) Protocol Routes Redistributed into IS-IS: None Number of Routes Redistributed into IS-IS: 0 Level-1 Auth-mode: None Level-2 Auth-mode: None Metric Style Supported for Level-1: Narrow Metric Style Supported for Level-2: Narrow Graceful-Restart Helper Support: Enabled ISIS Partial SPF Optimizations: Enabled Timers: L1 SPF: Max-wait 5s Init-wait 5000ms Second-wait 5000ms L2 SPF: Max-wait 5s Init-wait 5000ms Second-wait 5000ms L1 SPF is not scheduled L2 SPF is not scheduled PSPF: Max-wait 5000ms Init-wait 2000ms Second-wait 5000ms PSPF is not scheduled LSP: max-lifetime 1200s refresh-interval 900s gen-interval 10s retransmit-interval 5s, lsp-interval 33ms SNP: csnp-interval 10s psnp-interval 2s Global Hello Padding: Enabled Global Hello Padding For Point to Point Circuits: Enabled Ptpt Three Way HandShake Mechanism: Enabled BGP Ipv4 Converged: False BGP Ipv6 Converged: False IS-IS Traffic Engineering Support: Disabled No ISIS Shortcuts Configured BFD: Disabled, BFD HoldoverInterval: 0 NSR: Disabled LSP-SYNC: Not Globally Enabled
device# show isis config router isis net 11.768e.f805.5812.00 address-family ipv4 unicast ! address-family ipv6 unicast !
device# show isis counts Area Mismatch: 0 Max Area Mismatch: 0 System ID Length Mismatch: 0 LSP Sequence Number Skipped: 0 LSP Max Sequence Number Exceeded: 0 Level-1 Database Overload: 1 Level-2 Database Overload: 0 Our LSP Purged: 2
device# show isis hostname Total number of entries in IS-IS Hostname Table: 1 System ID Hostname * = local IS ---------------------------------------------------- * 768e.f805.5812 R1
device# show isis interface Total number of IS-IS Interfaces: 11 Interface: Ve 301 Circuit State: UP Circuit Mode: Level 1-2 Circuit Type: BCAST Passive State: FALSE Circuit Number: 2, MTU: 1500 Level-1 Auth-mode: NONE Level-2 Auth-mode: NONE Level-1 Metric: 10, Level-1 Priority: 64 Level-1 Hello Interval: 10, Level-1 Hello Multiplier: 3 Level-1 Designated IS: R1-02 Level-1 DIS Changes: 2 Level-2 Metric: 10, Level-2 Priority: 64 Level-2 Hello Interval: 10, Level-2 Hello Multiplier: 3 Level-2 Designated IS: R1-02 Level-2 DIS Changes: 2 Next IS-IS LAN Level-2 Hello in 11 seconds Number of active Level-2 adjacencies: 0 Next IS-IS LAN Level-1 Hello in 1 seconds Number of active Level-1 adjacencies: 0 Circuit State Changes: 1 Circuit Adjacencies State Changes: 0 Rejected Adjacencies: 0 Circuit Authentication L1 failures: 0 Circuit Authentication L2 failures: 0 Bad LSPs: 0 Control Messages Sent: 7577 Control Messages Received: 0 Hello Padding: Enabled IP Enabled: TRUE IP Addresses: 11.2.1.1/30 IPv6 Enabled: FALSE MPLS TE Enabled: FALSE BFD Enabled: FALSE LDP-SYNC: Disabled, State: …
device# show isis interface brief Total number of IS-IS Interfaces: 11 Interface Type State Mode Passive MTU UpAdj DIS StateChg AdjStateChg Ve 301 BCAST UP L12 FALSE 1500 0 None 1 0 Ve 302 BCAST UP L12 FALSE 1500 0 None 1 0 Ve 303 BCAST UP L12 FALSE 1500 0 None 1 0 Ve 304 BCAST UP L12 FALSE 1500 0 None 1 0 Ve 305 BCAST UP L12 FALSE 1500 0 None 1 0 Ve 306 BCAST UP L12 FALSE 1500 0 None 1 0 Ve 307 BCAST UP L12 FALSE 1500 0 None 1 0 Ve 308 BCAST UP L12 FALSE 1500 0 None 1 0 Ve 309 BCAST UP L12 FALSE 1500 0 None 1 0 Ve 310 BCAST UP L12 FALSE 1500 0 None 1 0 Lo 1 BCAST UP L12 TRUE 0 0 None 1 0
device# show isis neighbor
device# show isis spf-log ISIS Level-1 SPF Log When Duration Nodes Count Last-Trigger-LSP Trigger 10h34m13s 0ms 1 10 R1.00-00 Interface State Change 10h34m38s 0ms 1 2 R1.00-00 Interface Config Change 10h34m43s 0ms 1 18 R1.00-00 Interface Config Change 10h34m48s 0ms 1 5 R1.00-00 Interface State Change ISIS Level-2 SPF Log When Duration Nodes Count Last-Trigger-LSP Trigger 10h34m13s 0ms 1 10 R1.00-00 Interface State Change 10h34m38s 0ms 1 2 R1.00-00 Interface Config Change 10h34m43s 0ms 1 18 R1.00-00 Interface Config Change 10h34m48s 0ms 1 5 R1.00-00 Interface State Change
show isis traffic
Message Received Message Sent
Level-1 Hellos 0 44912
Level-2 Hellos 0 44927
PTP Hellos 0 0
Level-1 LSP 0 0
Level-2 LSP 0 0
Level-1 CSNP 0 0
Level-2 CSNP 0 0
Level-1 PSNP 0 0
Level-2 PSNP 0 0
