device(config-bgp-router)# ?
Possible completions:
address-family Enter Address Family command mode
always-compare-med Allow comparing MED from different neighbors
as-path-ignore Ignore AS_PATH length for best route selection
auto-shutdown-new-neighbors Auto shutdown new neighbor
capability Set capability
cluster-id Configure Route-Reflector Cluster-ID
compare-med-empty-aspath Allow comparing MED from different neighbors
even with empty as-path attribute
compare-routerid Compare router-id for identical BGP paths
confederation Configure AS confederation parameters
default-local-preference Configure default local preference value
describe Display transparent command information
distance Define an administrative distance
enforce-first-as Enforce the first AS for EBGP routes
fast-external-fallover Reset session if link to EBGP peer goes down
install-igp-cost Install igp cost to nexthop instead of MED
value as BGP route cost
local-as Configure local AS number
log-dampening-debug Log dampening debug messages
maxas-limit Impose limit on number of ASes in AS-PATH
attribute
med-missing-as-worst Consider routes missing MED attribute asleast
desirable
neighbor Specify a neighbor router
timers Adjust routing timers
The following neighbor configuration options are allowed under BGP global configuration mode:
device(config-bgp-router)# neighbor 2001:2018:8192::125 ?
advertisement-interval Minimum interval between sending BGP routing updates
as-override Override matching AS-number while sending update
capability Advertise capability to the peer
description Neighbor by description
ebgp-btsh Enable EBGP TTL Security Hack Protection
ebgp-multihop Allow EBGP neighbors not on directly connected
networks
local-as Assign local-as number to neighbor
maxas-limit Impose limit on number of ASes in AS-PATH attribute
next-hop-self Disable the next hop calculation for this neighbor
password Enable TCP-MD5 password protection
peer-group Create Peer Group
remote-as Specify a BGP neighbor
remove-private-as Remove private AS number from outbound updates
shutdown Administratively shut down this neighbor
soft-reconfiguration Per neighbor soft reconfiguration
static-network-edge Neighbor as special service edge, static-network
shall not be advertised if installed as DROP
timers BGP per neighbor timers
update-source Source of routing updates
