5320-16P-4XE Switch Features
The front panel of the switch includes:
- 1 = Serial console port (RJ-45)
- 2 = USB Type-A port for management or external USB flash
- 3 = USB Micro-B console port
- 4 =16 x 10/100/1000BASE-T (autosensing) MACsec capable ports with 802.3at Type 2 PoE (30W)
The 10/100 ports support half duplex; the 1000 port supports full duplex. Half-duplex is not supported on these ports when operating at 1Gbps.
- 5 = 2 x 1/10Gb SFP MACsec capable uplink ports
- 6 = 2 x 10Gb SFP+ Universal Ports/stacking ports (unpopulated)
5320-16P-4XE Front Panel
The rear panel of the switch includes:
- 1 = Kensington lock
- 2 = AC power inlet connector
- 3 = Grounding lug
- 4 = Cable tie mount for power cord management
5320-16P-4XE Rear Panel
