65 W AC Power Supply
The 65 W AC power supply is a fixed internal unit for model 5320-24T-4X-XT.
Voltage input range |
90-132/198-264 47 to 63Hz~ |
Nominal input ratings |
1.5A max at 100VAC and 1.0A max at 240VAC at Full 65 W load |
Maximum inrush current |
60A at Max 230VAC / 50Hz at 25C |
Output |
12V @65W |
Power supply input socket and cord |
IEC/EN 60320-1/C14 AC input receptacles |
Power cord wall plug |
Refer to Power Cord Requirements for AC-Powered Switches and AC Power Supplies |
Efficiency |
Minimum 88% at maximum power output |
90 W AC Power Supply
The 90 W AC power supply is a fixed internal unit for models 5320-24T-8XE and 5320-48T-8XE.
90-132/198-264 ~ 47 to 63Hz ~ |
1.2A max at 115VAC and 0.6A max at 230VAC at Full 90W load |
130A at Max 230VAC / 50Hz at 25C |
Output |
12V, 7.5A max, 90W |
Efficiency |
Minimum efficiency: 85% at maximum power output 115VAC |
150 W AC Power Supply
The 150 W AC power supply is a fixed internal unit for model 5320-24T-24S-4XE-XT.
90-132/198-264 ~ 47 to 63Hz |
1.8A max at 115Vrms |
120A at Max 230VAC / 50Hz at 25C |
Output |
12V, 12.5A @150W |
Efficiency |
Minimum 87% at maximum power output |
250 W AC Power Supply
The 250 W AC power supply is a fixed internal unit for model 5320-16P-4XE.
3.8A max at 90VAC at Full 250W load |
Output |
12V, 4.58A max, 54V, 3.61A max, 250W |
Efficiency |
Minimum efficiency: 90% at maximum power output 115VAC |
305 W AC Power Supply
The 305 W AC power supply is a fixed internal unit for model 5320-16P-2MXT-2X.
90-132/198-264 ~ 47 to 63Hzto |
| Nominal input ratings | 100-240 V, 50/60Hz, 4A max |
| Maximum inrush current | 30A at Max 115V, 60A at 230V |
| Output | 12V, 5A max, 54V, 4.5A max 305 W |
| Power supply input socket and cord | IEC/EN 60320-1/C16 AC input receptacles for use with a IEC/EN 60320-1/C15 cord |
| Power cord wall plug | Power Cord Requirements for AC-Powered Switches and AC Power Supplies |
| Efficiency | Minimum efficiency: 85% at maximum power output 115VAC |
550 W AC Power Supply
The 550 W AC power supply is a fixed internal unit for model 5320-24P-8XE.
90-132/180-264 ~ 47 to 63Hz |
8.5A max at 90VAC at Full 550 W load |
30A at Max 115VAC / 60Hz at 40C |
Output |
12V, 12.5A max, 54V, 7.4A max 550 W |
Efficiency |
Minimum efficiency: 87% at maximum power output 115VAC |
950 W AC Power Supply
The 950 W AC power supply is a fixed internal unit for model 5320-48P-8XE.
15A max at 90VAC and 7.5A max at 180VAC at Full 950 W load |
Output |
12V, 14.1A max, 55V, 14.2A max, 950 W |
Efficiency |
DC Power Supply
The DC power supply is a fixed internal unit for model 5320-16P-4XE-DC.
Voltage input range | 36 - 72V, 9.8 A max |
Nominal input |
48Vdc |
DC output |
12V/120W, 54V/200W |
150 W Redundant Power Supply
The 150 W redundant power supply can be used with models 5320-24T-4X-XT and 5320-24T-24S-4XE-XT.
AC Input |
100 - 240Vac, 50-60 Hz, 1.8A max. per PSU |
DC Output |
12Vdc, 12.5A max. total 150 W max. |
| Switch Model | Minimum Power Consumption (W) | Minimum Heat Dissipation (BTU/hr) | Maximum Power Consumption (W)* | Maximum Heat Dissipation (BTU/hr)** |
| 5320-16P-4XE | 17 | 57 | 246 | 208 |
| 5320-16P-4XE-DC | 20 | 67 | 260 | 256 |
| 5320-16P-2MXT-2X | 12.5 | 43 | 218 | 75 |
| 5320-24T-8XE | 18 | 60 | 50 | 171 |
| 5320-24P-8XE | 21 | 70 | 480 | 375 |
| 5320-48T-8XE | 25 | 85 | 64 | 217 |
| 5320-48P-8XE | 30 | 104 | 924 | 629 |
| 5320-24T-4X-XT | 14 | 35 | 49 | 119 |
| 5320-24T-24S-4XE-XT | 25 | 96 | 87 | 328 |
| Switch Model | PoE Budget |
| 5320-16P-4XE | 185W |
| 5320-16P-4XE-DC | 185W |
| 5320-16P-2MXT-2X | 180W |
| 5320-24P-8XE | 370W |
| 5320-48P-8XE | 740W |
