Use this task to configure VLAN settings on the Port Configuration page.
Typically, the default VLAN ID is 1.
You can also create a VLAN ID with a value of none. None clears the native VLAN from a port. (Switch Engine device only)See Configure a Classification Rule for more information.
For easier tracking, you might want to add the locations and device models using this VLAN classification rule (for example, VLAN-AP230-Sunnyvale).
Although optional, descriptions can be helpful when you are troubleshooting your network.
When selecting a location, drill down to the level where the devices are located. For example, if the devices are located on the floor of a building, select that specific floor.
