Instant Port Profiles (IPP) in ExtremeCloud IQ is an automated approach to configuring switch ports based on the connected devices. IPP streamlines the management of network-connected devices, such as access points (AP), security cameras, and VoIP devices by dynamically provisioning the appropriate port configuration automatically.
Some common use cases for IPP are:
IPP provides the capability to assign specific port profiles to client devices automatically, eliminating the need for manual port configuration by an administrator. When a user connects a device to a switch port, IPP allows the device to identify itself to the network system by its properties. Subsequently, IPP provisions the assigned port configuration, giving the device access to the network.
Create an IPP within the Switching Section of a Network Policy, assign IPP to ports within a switch template, or within the port configuration of a switch at device level configuration.
IPP allows for custom definitions (device types) and match criteria, enabling automatic VLAN assignment and storm control parameters. IPP offers more granular control over the network configuration based on specific device types.
If LLDP is disabled on a port:
However,LLDP Is Not Required If your Instant Port profile uses MAC-based matching only, then LLDP can be disabled and Instant Port will still work.
Match:
Category: MAC
OUI: "00:1A:2B"
In this case, Instant Port relies on MAC Learning from untagged traffic and does not need LLDP.
Important
Tagged packets cannot be classified by IPP. For devices expected to send tagged data frames, use only LLDP (Link Layer Discovery Protocol) match configuration.Each wired device type includes configuration that is dynamically applied to the port based on the match criteria. Dynamic configurations may include VLAN assignment and storm control parameters. VLAN configurations assign untagged VLANs based on the client's MAC address or assign tagged VLANs to the port.
The non-forwarding VLAN cannot be defined within a port type assigned to the switch; it is exclusively used for the Instant Port Profile feature.You can select a default port type for an Instant Port Profile. When port parameters cannot be dynamically set by the device type configuration, the default port type settings provide the configuration.
VLAN parameters on the default port type are applied. For example, if the default port type is a phone port and LLDP/CDP parameters are statically defined for the port, LLDP/CDP/MED is not enabled dynamically on the match actions.
Storm control settings are inherited when the non-match action is set to use the default port type, and a device does not match any defined device type.Section contents:
