Device Management
Use the following table to become familiar with the different symbolic representations in the Devices List on the ExtremeCloud IQ landing page. Hover over an icon on the page to display its name, then refer to the table.
Table 1. Device Status Icons
IconIcon NameDescription
AFC StatusAFC Status
Indicates an AFC issue with the selected device. Status options include Pending, Grace Period, and Spectrum Mismatch.
For more information, select the AFC status icon to open the AFC Wireless view of the selected device.
Provisioned DeviceProvisioned Device
An administrator has provisioned the device, but the device has not yet communicated with ExtremeCloud IQ.
This is an administrative state and does not reflect the actual connection status. To view the actual connection status, you must manually change the management state using the Actions > Change Manage Status > Managed Devices menu option.
Connected DeviceConnected DeviceDevice is actively communicating with ExtremeCloud IQ.
Disconnected DeviceDisconnected DeviceDevice is not actively communicating with ExtremeCloud IQ.
Cause: The device might be physically disconnected from the network or powered off. This condition also occurs if there are interruptions in the network between the device and ExtremeCloud IQ or when there are misconfigured firewalls or ACL rules.
Action: Ensure the device is connected to the network and powered on and ensure that communication can occur through logical barriers such as firewalls.
No ConnectionNo ConnectionThis device has not yet made a connection with ExtremeCloud‌ IQ (Classic). It can take up to 10 minutes for a device to appear after the initial onboarding process. If the device has not successfully connected after 10 minutes.
Configuration RollbackConfiguration Rollback
Device could not establish a connection to ExtremeCloud‌ IQ (Classic) after the configuration update. Device configuration rolled back to the last known good connection and the Updated status column displays Device update failed.
Simulated DeviceSimulated DeviceDevice is a simulated device, which possesses only simulated configurations, conditions, and traffic. By contrast, a real device has a physical presence on the network and consumes power and network resources.
Unknown DeviceUndeterminedDevice status is undetermined.
Cause: This condition can arise when the indicators are ambiguous, unknown, or appear contradictory due to other factors.
Action: Begin general troubleshooting procedures to ensure that the device is powered, connected, and is responding to traffic and CLI commands. Ensure that the device is communicating appropriately with network services, such as NTP, DHCP, etc.
Old OSOld OS Personality (Inactive)Device formerly used another OS persona, which is no longer active. The information in this record pertains to the device when it ran using this OS persona.
Configuration Audit MatchConfiguration Audit MatchThe network policy configuration matches the current running configuration.
Select the icon to open a pop-up window detailing the configuration changes that occurred since the last Update Devices operation.
  • Audit tab — lists any modifications made since the previous configuration update.
  • Delta tab — shows CLI commands that have changed since the previous update.
  • Complete tab — shows all CLI commands (including the CLI commands in the Delta tab) that form a configuration file. ExtremeCloud IQ uses this file for the next configuration update. After a successful configuration update, the configuration in the Complete tab matches the running configuration.
Note: Not applicable for locally managed switches.
Configuration Audit MismatchConfiguration Audit MismatchThe network policy configuration does not match the current running configuration.
Cause: The Configuration Audit Mismatch icon is visible on devices between the time that network policy changes are saved and the time that the altered network policy is uploaded to the device.
Action: Upload the network policy to the device.
Select the icon to open a pop-up window detailing the configuration changes that occurred since the last Update Devices operation. See the Configuration Audit Match icon description for details.
Pending ConfigurationPending ConfigurationDevice is currently offline and will receive its latest assigned configuration once it reconnects to the network.
Configured at Device LevelConfigured at Device LevelDevice possesses a device-level configuration that is different from the configuration defined in the network policy. This is not an error condition, but this information can be useful when troubleshooting network behavior because device-level configurations supersede device templates and network policy configurations.
anchorAnchorDevice is set as an anchor in an indoor AFC deployment.
Device Update UnsuccessfulDevice Update UnsuccessfulDevice did not accept the OS or configuration upload.
Cause: There are many reasons for an unsuccessful update, but the most common include network connectivity or connection status changes, or the device rejected the command it received.
Action: Hover over the update message in the Updated column to view the reason message describing the likely error condition. Ensure that the device is properly powered, that there is appropriate network connectivity, and that common causes listed here are not the issue.
Managed by Extreme IoTManaged by ExtremeIoTDevice is provisioned to function with ExtremeIoT.
Thread Commissioner RunningThread Commissioner RunningThe AP is designated Commissioner in the IoT Thread network.
Monitoring Unassociated ClientsMonitoring Unassociated ClientsDevice is using presence analytics to monitor client devices that are not associated to the network, such as passersby.
Switch StackSwitch StackDevice is a switch stack.
Select the icon to expand the device list view to include details for the switch stack members.
Switch Stack WarningSwitch Stack WarningOne or more stack member switches is not associated to the master stack node.
Cause: One or more member switches within a stack has lost connectivity to the master stack node. This can happen if the member switch is powered off, physically disconnected from the stack, or if there is an issue with the switch itself.
Action: Ensure that the switch slot has power and that the stacking cables are properly connected.
RadSec Proxy ServerRadSec Proxy ServerDevice is acting as a RadSec proxy server. This service optimizes some authentication functions, especially for cloud authentication, such as cloud PPSK and cloud RADIUS.
Rogue AP Mitigation OnRogue AP Mitigation OnDevice is actively mitigating a rogue access point. Refer to the information provided by your security management platform.
Sensor Mode Interface ActiveSensor Mode - Interface ActiveDevice is functioning as a sensor and the monitoring interface is active and monitoring the RF environment.
Sensor Mode InactiveSensor Mode - Interface InactiveDevice is functioning as a sensor, but the monitoring interface is not active and is not monitoring the RF environment.
Spectrum IntelligenceSpectrum IntelligenceDevice is functioning as a Spectrum Intelligence monitor, which monitors the RF environment and provides frequency and time domain graphs and heat maps.
VPN Server - Tunnel UpDevice is functioning as a VPN server and the VPN tunnel is up, healthy, and operating properly.
VPN Server - Tunnel DownDevice is functioning as a VPN server, but the VPN tunnel is down. If the tunnel is administratively down, then this is not an error condition.
Cause: If not administratively down, issues on the client side can cause the tunnel to go down. Additionally, if the client- and server-side configuration do not agree, then a tunnel cannot be built.
Action: Consult the VPN troubleshooting tools in ExtremeCloud IQ. You can also ensure that the client device is connected to the network and that the tunnel configurations agree on both ends of the tunnel.
VPN Server - Tunnels Up and DownSome of the VPN server tunnels are administratively up but operationally down.
Cause: VPN client might be down, or unreachable.
Action: Ensure that the VPN clients are powered on, connected to the network, and communicating with ExtremeCloud IQ. In addition, ensure that there is connectivity and communication between the VPN server and clients.
VPN Client Tunnels UpVPN Client - Tunnels UpDevice is functioning as a VPN client and the VPN tunnel is up, healthy, and operating properly.
VPN Client Tunnels DownVPN Client - Tunnels DownDevice is functioning as a VPN client, but the VPN tunnel is down. If the tunnel is administratively down, then this is not an error condition.
Cause: If not administratively down, issues on the server side can cause the tunnel to go down. Additionally, if the client- and server-side configuration do not agree, then a tunnel cannot be built.
Action: Consult the VPN troubleshooting tools in ExtremeCloud IQ. You can also ensure that the server device is connected to the network and that the tunnel configurations agree on both ends of the tunnel.
VPN Client Tunnels Up and DownVPN Client - Tunnels Up and DownSome of the VPN client tunnels are administratively up but operationally down.
Cause: VPN server might be down, or unreachable.
Action: Ensure that the VPN server is powered on, connected to the network, and communicating with ExtremeCloud IQ. In addition, ensure that there is connectivity and communication between the VPN server and client.
Locally Managed with ExtremeCloud IQLocally Managed Device is managed by a platform other than ExtremeCloud IQ, but it is monitored by ExtremeCloud IQ. For example, other platforms can include 3rd party, ExtremeCloud IQ Site Engine, or ExtremeCloud IQ Controller.
Locally Managed without ExtremeCloud IQLocally Managed (No ExtremeCloud IQ)Device or its management platform are not visible in ExtremeCloud IQ.
Cause: This is not always an error condition, but it can indicate a status communication problem. In this case, the device is functioning properly, so there is no disruption in network performance; instead, the status communication is disrupted so that ExtremeCloud IQ is unaware of the status.
Action: First, ensure that the device is functioning properly to rule out problems with the device. Next, ensure that there are no logical barriers between the device and ExtremeCloud IQ. Afterward, ensure that any applications that lie in the communication path are receiving, processing, and sending data appropriately.
ExtremeCloud Appliance Cluster ClosedExtremeCloud Appliance Cluster (Closed)Device is a logical cluster of appliances, but the cluster is collapsed visually to appear as a single device.
ExtremeCloud Appliance Cluster OpenExtremeCloud Appliance Cluster (Open)Device is a logical cluster of appliances, but the cluster is expanded visually to reveal the cluster members.
Fabric AttachFabric AttachDevice is a member of the Fabric Attach Connect Automation environment and is functioning properly in that context.
Fabric Attach IssueFabric Attach IssueDevice is Fabric Attach capable, but the Fabric Attach (FA) session to the FA server is not established.
Cause: This can occur if the communication link between the FA device and server is disrupted or if FA is disabled on the peer switch.
Action: Ensure that there is connectivity between FA device and server, and that FA server functionality is enabled on the peer switch.
Digital Twin
Digital TwinDevice is a simulated device.
FIPS Mode Device is in FIPS mode.
