Syslog Server Settings
Table 1. Settings for Syslog servers
SettingDescription
NameType a Name for the syslog server.
Description(Optional)
Type a Description for the syslog server. Although optional, descriptions can be helpful when you are troubleshooting your network.
Syslog Facility
IQ Engine Syslog FacilitySelect an IQ Engine Syslog Facility to categorize messages sent to syslog from IQ Engine devices.
Because syslog servers can receive messages from many types of network devices, such as routers, firewalls, mail servers, you can designate one of the twelve syslog facilities reserved for local use—Auth, Authpriv, Security, User, and Local0 to Local7—to mark messages from all the devices to which you apply this management service set.
Non-IQ Syslog FacilitySelect a Non-IQ Syslog Facility to categorize messages sent to syslog from non-IQ Engine devices.
Syslog GroupSelect the arrow to expand the Syslog Group section, and use the menus to select the log level for each category.
  • Emergency
  • Alert
  • Critical
  • Error
  • Warning
  • Notification
  • Info
  • Debug
Syslog groups organize messages by category and limit the number of messages sent based on severity level. APs do not send messages that are below the assigned level to the syslog server.
Syslog servers are on the same internal network as the reporting Extreme Networks devices (for PCI DSS compliance)If you must make PCI DSS compliance reports, select the check box. If the servers are on an external network outside the firewall, clear the check box.
Enable hostname in syslog headersTo add the hostname to the headers for all syslog messages, select the check box.
