Onboard the device and select Next: Topology.
The list at the top of the dialog box shows the locations in your network and the
number of devices assigned at each location (in purple), if any. Reference the
location list for this task.
- Select a floor from the location
list to display the floor plan.
- Select one or multiple devices from the list of unassigned devices and drag
them to the floor map.
You can use the type-ahead search box to locate devices or the filter tool to
narrow your search.
- Use the pencil icon to edit the device name.
- Select Finish.
After connection to ExtremeCloud IQ, the device status changes from Red to Green. It can take up to 3 minutes.
