Use this task to set up a new ExtremeCloud IQ network and onboard and manage devices.
The first time you log in, the onboarding panel opens to the right of the main window. For
subsequent log ins, to see this panel, select the expand arrow in the blue rectangle
on the right edge of any window.
- Name your organization, then
select Continue.
- Choose to deploy and manage your devices in the cloud, then select
Let‘s get started.
- Add a Location, then select Save Location.
- Select Next: Building.
- Add a Building, then select Save Building.
- Select Next: Floor.
- Add a Floor, associate it with a building, select an environment from the
options, enter the floor attenuation, and the device installation height.
Select
Choose from Library to import a floor plan
image.
- Choose to onboard Real device.
- Enter the device serial number.
- For the Device OS, choose Switch
Engine or Fabric Engine before you can
onboard a Universal Hardware Switch.
- Select Onboard Devices.
- Select Next: Topology.
