Configure LLDP and CDP Policy Settings
This task is part of the network policy configuration workflow. Use this task to configure LLDP/CDP policy settings for a network policy.
LLDP is on by default in ExtremeCloud IQ. In IQ Engine, LLDP was previously off by default. With IQ Engine Release 10.7.5 and later, LLDP is on by default. This is the new default behavior for all new devices running 10.7.5 and later.
If LLDP is disabled in the network policy, upgrading to 10.7.5 enables LLDP until after you perform a configuration update.
  1. Select an existing network policy, and then select Edit, or select Add to create a new policy.
  2. From the Policy Settings menu, select LLDP/CDP.
  3. Toggle the LLDP/CDP setting to ON.
  4. Optional: To use existing LLDP/CDP settings, choose an LLDP/CDP object from the Select menu.
  5. Configure the settings.
  6. Select SAVE.
