Network Allocation supports the creation of IP subnetwork configuration. A subnetwork
with a selected VLAN can be applied to a device within the Routing section. When
entries are added in the Network Allocation table, the Local IP Address Space field
is valid only if it‘s a subnet address, not a host address. This table allows the
user to create subnetworks which will be then used to the configure IP addresses per
VLAN in the next table.
A VLAN defined within Instant Port
Profiles as Non-Forwarding cannot be used to create a subnetwork.
On the Network
Allocation page, you can add, edit, or delete Network Allocation
configurations. The table includes the following parameters:
Name
Description
IPv4 Subnetwork
Clients Per Subnet
DHCP Relay
VLAN Name
VLAN ID
VLAN Used By
Use this task to configure Network Allocation at the template level.
Go to Configure > Network
Policies.
Create or select a Network
Policy.
Select Switching > Routing > Network
Allocation.
Select to add or to edit.
Network Allocation
Configure the following IPv4
Network Allocation settings:
Table 1. Network Allocation
Settings
Setting
Description
VLAN Attribute
A VLAN attribute can be created from within the VLAN
attribute section within the Network Policy Switching
Section.
Name
The name of your subnetwork.
Description
A description of your subnetwork.
Define the local IP address space using CIDR notation,
such as 10.1.0.0/16.
At the template level the IP address must be the valid
network address and not a host address within the subnet
range you are creating.
Clients Per Subnet
Shows the clients per subnet.
Select One
Use the first IP address of the local IP address
space for the IPv4 interface
Use the last IP address of the local IP address
Enable DHCP Relay
Enable DHCP Relay. If enabled, select or create a DHCP
Relay Common Object.
DHCP Server and Relay
Object
Template-level IP Address
Specifications
If 10.35.1.161/30 is the host address, then to create a valid Network Allocation
entry in the network policy switch routing section you must introduce 10.35.1.160/30
in the Local IP Address Space field or you will receive an "Invalid Network" error.
Error Message
Using 10.35.1.160 will create the following IP Address parameters:
Network Address (10.35.1.160) - Can be used in the Network Allocation table.
Usable Host IP Range (10.35.1.161 - 10.35.1.162) - Can be used in the Routing
table.
Broadcast Address (10.35.1.163) - Unable to use for ExtremeCloud IQ (Classic)
or NOS.
When entries are added in a Routing table, the IPv4 Address / Subnet Mask is valid if
a host address is used, and this is the IP address that will be configured on the
VLAN.
