Two AC power supply options, with front-to-back or back-to-front airflow, are are available for the switch:
Power supplies are ordered separately for the base SLX 9740 switch. Power supplies are included with other switches.
The 1600 W AC power supply has a (C14) power inlet that requires a (C13) power cord.
AC power input cords are not provided with AC power supplies. You can order an appropriate cord from Extreme Networks or from your local supplier. The power cord must meet the requirements listed in Power Cord Requirements for AC-Powered Switches and AC Power Supplies.LEDs on the power supplies provide information on the unit's operational status. The LEDs are located on the end of the power supply unit, arranged vertically to the left of the power cord receptacle. The following tables describe the meanings of the LEDs on the DC power supply.
| Label and Color | Description | State | Meaning |
| ! Amber | Fault indicator | On (Solid | PSU fault |
| Off | No PSU fault | ||
| DC (Green) | DC output good | On (Solid | DC output OK |
| Off or blinking | DC output fail | ||
| AC (Green) | AC input good | On | AC input OK |
| Off | AC input fail |
For information on installing or replacing a power supply, see Replace Power Supplies.
