Precautions Specific to Transceivers and Cables
Warning
Warning
All fiber-optic interfaces use Class 1 lasers.
Warning
Warning
Use only optical transceivers that are qualified by Extreme Networks, Inc. and comply with the FDA Class 1 radiation performance requirements defined in 21 CFR Subchapter I, and with IEC 60825 and EN60825. Optical products that do not comply with these standards might emit light that is hazardous to the eyes.
Caution
Caution
Do not use the port cover tabs to lift the module. They are not designed to support the weight of the module, which can fall and be damaged.
Caution
Caution
Before plugging a cable into any port, be sure to discharge the voltage stored on the cable by touching the electrical contacts to ground surface.
