| Part number | Description |
| SLX 9740-40C, 9740-40C | SLX 9740-40C, 9740-40C switch router with two unpopulated power supply slots and six unpopulated fan slots. Supports 40x100GE/40GE QSFP28 ports. |
| SLX 9740-40C-AC-F | SLX 9740-40C-AC-F switch router AC with front-to-back airflow. Supports 40x100GE/40GE QSFP28 ports with dual power supplies, six fans. |
| SLX 9740-80C, 9740-80C | SLX 9740-80C, 9740-80C switch router with four unpopulated power supply slots and four unpopulated fan slots. Supports 80x100GE/40GE QSFP28 ports. |
| SLX 9740-80C-AC-F | SLX 9740-80C-AC-F switch router AC with front-to-back airflow. Supports 80x100GE/40GE QSFP28 ports with quad power supplies, four fans. |
| Switch | Weight | Physical Dimensions |
| SLX9740-40C | 10.55 kg (23.28 lb) | Height: 4.31 cm (1.7 in)
Width: 45.00 cm (17.72 in) Length (base switch): 64.00 cm (25.2 in) Length (40C-AC-F switch): 67.00 cm (26.38 in) |
| SLX9740-40C switch with two AC PSUs (-F and -R switches) | 13.62 kg (30.04 lb) | |
| SLX9740-80C | 20.61 kg (45.45 lb) | Height: 8.66 cm (3.41 in)
Width: 45.00 cm (17.72 in) Length (base switch): 64.00 cm (25.2 in) Length (80C-AC-F switch): 67.00 cm (26.38 in) |
| SLX9740-80C switch with four AC PSUs (-F and -R switches) | 26.48 kg (58.40 lb) | |
| XN-FAN-003-F: Fan unit, front-to-back or FAN-003-R: Fan unit back-to-front for SLX9740-40C | 0.12 kg (0.28 lb) | Height: 4.01 cm (1.58 in.)
Width: 4.01 cm (1.58 in.) Length: 13.99 cm (5.51 in.) |
| XN-FAN-004-F: Fan unit, front-to-back or FAN-004-R: Fan unit back-to-front for SLX9740-80C | 0.31 kg (0.70 lb) | Height: 5.99 cm (2.36 in.)
Width: 4.01 cm (2.36 in.) Length: 15.49 cm (6.1 in.) |
| XN-4P-RKMT302 - Four-post rack mount kit for SLX9740-40C (included with switch) | 2.83 kg (6.26 lb) | Height: 5.00 cm (1.97 in)
Width: 7.01 cm (2.76 in) Length: 72.00 cm (28.35 in) |
| XN-4P-RKMT301 - Four-post rack mount kit for SLX9740-80C (included with switch) | 2.95 kg (6.52 lb) | |
| XN-2P-RKMT299 - Two-post rack mount kit for SLX9740-40C (ordered separately) | 0.45 kg (0.99 lb | Height: 4.2 cm (1.65 in)
Width: 2.4 cm (0.93 in) Length: 12.5 cm (4.92 in) |
| XN-2P-RKMT300 - Two-post rack mount kit for SLX9740-80C (ordered separately) | 0.70 kg (1.54 lb) | Height: 8.99 cm (3.54 in)
Width: 10.16 cm (4.00 in) Length: 13.00 cm (5.12 in) |
| 1600 W power supply – AC front-to-back or back-to-front airflow | 1.15 kg (2.53 lb) | Height: 4.01 cm (1.58 in)
Width: 8.63 cm (3.4 in) Depth: 24.00 cm (9.45 in) |
| 1600 W power supply – DC front-to-back airflow | Height: 4.01 cm (1.58 in)
Width: 8.63 cm (3.4 in) Depth: 25.50 cm (10.04 in) |
