| Connector options |
- 40 100 GbE/40GbE ports for 9740-40C
- 80 100 GbE/40GbE ports for 9740-80C
- 72 (18x4) 10/25 GbE ports for 9740-40C
- 144 (36x4) 10/25 GbE ports for 9740-80C
- Out-of-band Ethernet management: 10/100/1000 Mbps RJ-45
- Console management: RJ45 serial port
- Storage: USB port, standard-A plug
| Maximum MAC addresses | 600K (default profile) 190K (route profile)
| Switch fabric capacity (data rate, full duplex) | 4.0 Tbps in each direction (front panel ports, 40x100Gbps) for 9740-40C 8.0 Tbps in each direction (front panel port, 80x100Gbps) for 9740-80C |
| Maximum VLANs | 4,096 |
| Maximum ACLs (IPv4/IPv6/L2) | 2,000 |
| Maximum members in a standard LAG | 64 |
| Maximum number of MCT switches | 2 |
| Maximum number of Bridge Domains | 4,096 |
| Maximum IPv4 unicast routes | 128,000 |
| Maximum IPv6 unicast routes | 10,000 |
| Maximum IPv4 host routes | 47,000 |
| Maximum IPv6 host routes | 33,000 |
| Maximum jumbo frame size | 9,216 bytes |
| QoS priority queues (per port) | 8 |
| IEEE Compliance | - IEEE 802.1D Spanning Tree Protocol
- IEEE 802.1s Multiple Spanning Tree
- IEEE 802.1w Rapid Reconfiguration of
- IEEE 802.3 Ethernet
- IEEE 802.3ad Link Aggregation with
LACP
- IEEE 802.3ab 1000BASE-T
- IEEE 802.3z 1000BASE-X
- IEEE 802.3ba / 80 2.3bm 40 GBASE-X
and 100 GBASE-X
- IEEE 802.1Q VLAN Tagging
- IEEE 802.1p Class of Service
Prioritization and Tagging
- IEEE 802.1v VLAN Classification by
Protocol and Port
- IEEE 802.1AB Link Layer Discovery
Protocol (LLDP)
- IEEE 802.3x Flow Control (Pause
Frames)
- IEEE 802.3ae 10 GBASE-X
- IEEE 802.3 10 GBASE-T (up to 100 m
using Cat6a cabling or better)
- IEEE 802.3bj
- IEEE 802.3by
