Three 1600 W power supply units are available for use with SLX 9740 switches:
| SLX 9740 Switch |
1600 W AC power supply:
1600 W DC power supply:
| SLX 9740-80C (Fans high, all ports 100% traffic, 4 PSU) | SLX 9740-40C (Fans high, all ports 100% traffic, 2 PSU) | |
| Maximum Heat Dissipation | 6592.26 BTU/hr | 3524.74 BTU/hr |
| Maximum Power Dissipation | 1932W | 1033W |
| Voltage input range |
| Nominal input ratings |
| Nominal input current at full loads |
| Line frequency range |
| Maximum inrush current |
| Output |
| Efficiency |
| Nominal input | -48 to -60 VDC |
| DC Voltage input range | +/-39VDC to +/-72VDC, 15A max. |
| Inrush Current | 21 A peak |
| DC Output | +12.2V/131A, +12Vsb/2.5A |
| Power (W) | 1600 W |
| Operating temperature (front- to-back airflow) | 0°C to 45°C (normal operation) |
| Operating temperature (back- to-front airflow) | 0°C to 45°C (normal operation) |
| Storage temperature | -40°C to 70°C |
| Operating humidity | 5% to 95% relative humidity, non-condensing |
| Operational shock | 30 m/s2 (3 G) |
