IP addresses can be assigned to an Ethernet interface, using Classless Interdomain Routing (CIDR) network masks.
device# configure terminal
device(config)# interface ethernet 0/1
device(config-if-eth-0/1)# ip address 11.1.1.11/24 device(config-if-eth-0/1)# ip address 11.11.1.11/24
device(config-if-eth-0/1)# ip address 10.53.5.4/24 secondary
You can configure a secondary IP address only if the primary IP address is already configured in the same subnet.device(config-if-eth-0/1)# no shutdown
device(config-if-eth-0/1)# do show ip interface ethernet 3/14 Ethernet 3/14 is up protocol is up Primary Internet Address is 11.1.1.11/24 broadcast is 11.1.1.255 Primary Internet Address is 11.11.1.11/24 broadcast is 11.11.1.255 Secondary Internet Address is 11.11.1.12/24 broadcast is 11.11.1.255 IP MTU is 1500 Proxy Arp is Enabled ICMP unreachables are always sent ICMP mask replies are never sent IP fast switching is enabled Vrf : default-vrf
