Extreme SLX-OS Layer 3 Routing Configuration Guide, 20.2.2a
> DHCPv6
Published November 2020
Preface
Getting Help
Providing Feedback
About This Document
What‘s New in this Document
Supported Hardware
ARP Overview
Enable ARP Learning
Proxy ARP
ARP Poisoning
Apply an ARP ACL to a VLAN
Enable DAI on a VLAN
DAI Show and Clear Commands
ARP Guard
ARP Suppression
Suppress ARP on a VLAN
Conversational ARP
Enable Conversational ARP
ARP Show and Clear Commands
IPv4 Addressing
IPv4 Addressing Overview
ARP Cache
IP Parameters and Protocols
IP Global Parameters
IP Interface Parameters
Router-ID IP Addresses
Assign a Router-ID IP Address
Domain Name System
IPv6 Addressing
IPv6 Addressing Overview
IPv6 management
IPv6 Management ACLs
Secure Shell and IPv6
IPv6 Telnet
IPv6 Traceroute
Sending or Suppressing IPv6 Router Advertisements Globally
Neighbor redirect messages
Enable Conversational ND
Change the IPv6 MTU Value
IPv6 Prefix List
Configure an IPv6 Prefix List
Clear Global IPv6 Information
IPv4 Static Routing
Configure a Null Static Route
IPv6 Static Routing
Configuring a null route
Remove an IPv6 Static Route
Layer 3 Policy-based Routing
BFD
BFD for Layer 3 Protocols
BFD for BGP
BFD for OSPF
BFD for Static Routes
BFD over MCT and VxLAN
BFD for IS-IS
Enable BFD on an IS-IS-enabled Interface
Configure BFD for IS-IS Globally
Display BFD Information
BGP4
BGP4 Overview
BGP4 Peering
BGP4 Message Types
BGP4 parameters
BGP Device ID
Enable BGP4 Globally
BGP4 Neighbor Configuration
Configure a BGP4 Neighbor
BGP4 Dynamic Neighbors
Clear BGP4 Dynamic Neighbors
BGP4 Peer Groups
Create a BGP4 Peer Group
Four-byte AS Numbers for BGP4
Redistribute Routes into BGP4
Import Routes into BGP4
Static BGP4 Networks
BGP4 Route Reflection
Next-hop Recursion for BGP4
BGP4 Route Filters
BGP4 Outbound Route Filtering
BGP4 Route Maps
BGP4 Confederations
BGP Large Communities
BGP Flowspec
BGP Flowspec Considerations
Configure BGP Flowspec Rules
Distribute BGP Flowspec Rules
BGP4 graceful restart
Configuring BGP4 graceful restart
BGP4 Graceful Shutdown
BGP Additional-paths
BGP Best-External Route
Configure GTSM for BGP4
BGP4 Route Flap Dampening
Enable BGP4 Route Dampening
BGP4 Diagnostic Buffers
Display BGP4 Statistics
BGP PIC
BGP PIC functional scenarios
BGP PIC Considerations
Enable BGP PIC
BGP4+
BGP4+ Overview
BGP global mode
IPv6 unicast address family
BGP4+ Peer Groups
Create a BGP4+ Peer Group
BGP4+ Dynamic Neighbors
Clear BGP4+ Dynamic Neighbors
Importing routes into BGP4+
BGP4+ Route Reflection
BGP4+ Route Maps
BGP4+ confederations
BGP4+ extended community
BGP4+ graceful restart
Configuring BGP4+ graceful restart
Configure GTSM for BGP4+
Displaying BGP4+ statistics
Clearing BGP4+ dampened paths
BGP EVPN for IP Fabrics
BGP EVPN Overview
BGP EVPN Control Plane
BGP EVPN neighbor examples
BGP routing tables
BGP EVPN-based VxLAN Overlay
Layer 2 (MAC) route exchange
BGP EVPN VXLAN data center interconnect
Static Anycast Gateway
IP unnumbered interface
High availability
DHCPv4
DHCPv4 Overview
DHCPv4 Relay Overview
Configure the DHCPv4 Relay
DHCPv4 Snooping
DHCPv4 Relay Agent Option 82
VRF Support in DHCPv4
Clear DHCPv4 Relay Statistics
DHCPv6
DHCPv6 Overview
DHCPv6 Relay Agent
DHCPv6 Address Assignment
DHCPv6 Message Format
Configure DHCPv6 Relay
Clear DHCPv6 Relay Statistics
Generic Routing Encapsulation
GRE tunnels
Configuring a Tunnel
Enabling tunnel statistics
Configure MTU
Displaying tunnel statistics
Clearing tunnel statistics
IS-IS (IPv4)
IS-IS overview
Domain and areas
Neighbors and adjacencies
Designated IS
Broadcast pseudonode
IS-IS CLI levels
Enabling IS-IS globally
Overload bit
Setting the overload bit
Authentication
Configuring authentication
Logging adjacency changes
Configuring the CSNP interval
Changing the SPF timer
Hello padding
Partial SPF optimizations
Incremental SPF optimizations
Default route advertisement
IS-IS administrative distance
Configuring summary addresses
Default redistribution metric
IS-IS metric styles
Changing the metric style
DIS Hello Interval
Displaying IS-IS statistics
IS-IS (IPv6)
IS-IS CLI levels
Enabling IPv6 IS-IS globally
Configuring summary prefixes
IS-IS metric styles
IPv6 IS-IS Multi-Topology
Migrating to IPv6 IS-IS MT
Maintaining MT adjacencies
New TLV attributes
Enabling IPv6 IS-IS MT
Multi-VRF
Multi-VRF Overview
Configuring Multi-VRF
Configuring a VRF instance
Removing a VRF configuration
Inter-VRF Route Leaking
Internet Route Scaling
Configure the Profile Route
OSPFv2
OSPFv2 overview
Autonomous System
OSPFv2 components and roles
Enabling OSPFv2
Backbone area
Assigning OSPFv2 areas
Area range
Assigning an area range
Area types
Not-so-stubby area (NSSA)
Configuring an NSSA
Link state advertisements
Virtual links
Configuring virtual links
Default route origination
External route summarization
OSPFv2 LSA refreshes
OSPFv2 Graceful Restart
OSPFv2 Non-stop Routing
Enabling OSPFv2 NSR
OSPFv2 type 3 LSA filtering
OSPFv2 over VRF
Changing default settings
Disabling OSPFv2
Displaying OSPFv2 results
OSPFv3 overview
Configuring the router ID
Enabling OSPFv3
Configuring OSPFv3
OSPFv3 areas
Backbone area
Area range
Area types
Assigning OSPFv3 areas
Configuring a stub area
Not-so-stubby area
Configuring an NSSA
LSA types for OSPFv3
Virtual links
OSPFv3 route redistribution
Filtering OSPFv3 routes
SPF timers
Modifying SPF timers
OSPFv3 LSA refreshes
OSPFv3 over VRF
OSPFv3 Graceful Restart
OSPFv3 Non-stop Routing
Enabling OSPFv3 NSR
OSPFv3 max-metric router LSA
IPsec for OSPFv3
Displaying OSPFv3 results
VRRPv2
VRRPv2 overview
VRRP terminology
VRRP hold timer
VRRP interval timers
VRRP authentication
ARP and VRRP control packets
Enabling a master VRRP device
Enabling a backup VRRP device
VRRP multigroup clusters
VRRP backup preemption
Virtual router MAC address
VRRP-Ev2 overview
Enabling a VRRP-E device
Displaying VRRPv2 information
Clearing VRRPv2 statistics
VRRPv3 overview
Enabling IPv6 VRRPv3
Enabling IPv4 VRRPv3
VRRP hold timer
Displaying VRRPv3 statistics
Clearing VRRPv3 statistics
VRRP-Ev3 Overview
Enabling IPv6 VRRP-Ev3
VXLAN Layer 3 Gateway
VXLAN Layer 3 Gateway Overview
Single-VTEP static VLAN/VXLAN-VE Layer 3 gateway
Single-VTEP static BD/VXLAN-VE
EVPN-based VXLAN Layer 3 gateway
EVPN-based VXLAN Layer 3 gateway on LVTEP
Configuring VXLAN Layer 3 gateway
Example show and clear commands for VXLAN Layer 3 gateway
QoS for VXLAN Layer 2 and Layer 3 Gateway Interconnections
QoS for VXLAN Layer 3 Gateways
Resilient Hashing
Introduction
How Resilient Hashing Works
DHCPv6
