Implementing ARP Guard requires creating ARP ACLs, then applying and enabling them on interfaces and port-channels.
Follow these guidelines when implementing ARP Guard.
The following table indicates which hardware profiles support the various types of ARP Guard implementation. For more information, see the show hardware profile command in Extreme SLX-OS Command Reference.
Profile |
Basic ARP Guard |
ARP Guard with Rate Limiting |
ARP Guard on VPLS Endpoint |
ARP Guard on VPLS End- point with Rate Limiting |
default |
Yes |
Yes |
Yes |
Yes |
vxlan-visibility |
Yes |
No |
No |
No |
