Layer 3 gateway is supported only in the default TCAM profile.
This procedure requires a system reload to activate the profile configuration.device# configure terminal
device(config)# hardware
device(config-hardware)# profile tcam default
device(config-hardware)# exit
device# copy running-config startup config
device# reload system
This example summarizes the commands in the procedure.
device# configure terminal device(config)# hardware device(config-hardware)# profile tcam default device(config-hardware)# exit device# copy running-config startup config device# reload system
