BGP4 Message Types
BGP4 messages can be of the following types: OPEN, UPDATE, NOTIFICATION, KEEPALIVE,
or ROUTE-REFRESH.
All BGP4 messages use a common packet header,
with the following byte lengths:
| Marker |
Length |
Type |
Data |
| 16 |
2 |
1 |
variable |
All values in the following tables are in bytes.
OPEN message
After establishing TCP connection, BGP peers
exchange OPEN message to identify each other.
| Version |
Autonomous System |
Hold-Time |
BGP Identifier |
Optional Parameter Len |
Optional Parameters |
| 1 |
2 or 4 |
2 |
4 |
1 |
4 |
- Version
- Only BGP4 version 4 is supported.
- Autonomous System
- Both 2-byte and 4-byte autonomous system numbers are supported.
- KEEPALIVE and HOLDTIME timers
- A BGP timer command
specifies both keep-alive and hold-time
operands that manage the intervals for BGP KEEPALIVE and HOLDTIME messages.
The keep-alive time specifies how frequently the device sends KEEPALIVE
messages to its BGP4 neighbors. The hold-time specifies how long the device
waits for a KEEPALIVE or UPDATE message from a neighbor before concluding
that the neighbor is dead. When two neighbors have different hold-times, the
lowest value is used. A hold-time of 0 means "always consider neighbor to be
active."
- BGP Identifier
- Indicates the router (or device) ID of the sender. When a router-id is not
configured, the device-id is taken from the loopback interface. Otherwise,
the lowest IP address in the system is used.
- Parameter List
- An optional list of additional parameters used in peer negotiation.
UPDATE message
The UPDATE message advertises new routes,
withdraws previously advertised routes, or both. The UPDATE message passes BGP4
attributes to describe the characteristics of a BGP path by the advertising
device.
| Withdrawn Routes Length |
Withdrawn Routes |
Total Path Attributes Len |
Path Attributes |
NLRI |
| 2 |
variable |
2 |
variable |
variable |
- Withdrawn Routes Length
- Indicates the length of the next (withdrawn
routes) field. It can be 0.
- Withdrawn Routes
- Contains a list of routes (or
IP-prefix/Length) to indicate routes being withdrawn.
- Total Path Attribute Len
- Indicates the length of the next (path
attributes) field. It can be 0.
- Path Attributes
- Indicates characteristics of the advertised
path. Possible attributes: Origin, AS Path, Next Hop, MED (Multi-Exit
Discriminator), Local Preference, Atomic Aggregate, Aggregator, Community,
extended-Communities. All well-known attributes, as described in RFC 4271, are supported.
- NLRI
- Network Layer Reachability Information. The
set of destinations whose addresses are represented by one prefix. This
field contains a list of IP address prefixes for the advertised routes.
NOTIFICATION message
If an error causes the TCP connection to close,
the closing peer sends a notification message to indicate the type of error.
| Error Code |
Error Subcode |
Error Data |
| 1 |
1 |
variable |
- Error Code
- Indicates the type of error, which can be one of following:
- Message header error
- Open message error
- Update message error
- Hold timer expired
- Finite state-machine
error
- Cease (voluntarily)
- Error Subcode
- Provides specific information about the reported error.
- Error Data
- Provides data based on the error code and the subcode.
KEEPALIVE message
Because BGP does not regularly exchanges route
updates to maintain a session, KEEPALIVE messages are sent to keep the session
alive. The KEEPALIVE time specifies how frequently the device sends KEEPALIVE
A KEEPALIVE message contains the BGP header without a data field. The default
KEEPALIVE time is 60 seconds and is configurable.
REFRESH message
A REFRESH message is sent to a neighbor
requesting that the neighbor resend the route updates. This message is useful when
the inbound policy has been changed.
