The IPv6 unicast address family configuration level provides access to commands that allow you to configure BGP4+ unicast routes. The commands that you enter at this level apply only to the IPv6 unicast address family.
BGP4+ supports the IPv6 address family configuration level.
The commands that you can access while at the IPv6 unicast address family configuration level are also available at the IPv4 unicast address family configuration levels. Each address family configuration level allows you to access commands that apply to that particular address family only.
The following configuration options are allowed under BGP IPv6 address family unicast mode:
device(config-bgp-ipv6u)# ?
Possible completions:
aggregate-address Configure BGP aggregate entries
always-propagate Allow readvertisement of best BGP routes not
in IP Forwarding table
bgp-redistribute-internal Allow redistribution of iBGP routes into IGPs
client-to-client-reflection Configure client to client route reflection
dampening Enable route-flap dampening
default-information-originate Originate Default Information
default-metric Set metric of redistributed routes
graceful-restart Enables the BGP graceful restart capability
maximum-paths Forward packets over multiple paths
multipath Enable multipath for ibgp or ebgp neighbors
only
neighbor Specify a neighbor router
network Specify a network to announce via BGP
next-hop-enable-default Enable default route for BGP next-hop lookup
next-hop-recursion Perform next-hop recursive lookup for BGP
route
redistribute Redistribute information from another
routing protocol
rib-route-limit Limit BGP rib count in routing table
table-map Map external entry attributes into routing
table
update-time Configure igp route update interval
only
route
routing protocol
table
The following neighbor configuration options are allowed under BGP IPv6 address family unicast mode:
device(config-bgp-ipv6u)# neighbor 2001:2018:8192::125 ?
activate Allow exchange of route in the current family mode
allowas-in Disables the AS_PATH check of the routes learned
from the AS
capability Advertise capability to the peer
default-originate Originate default route to peer
filter-list Establish BGP filters
maximum-prefix Maximum number of prefix accept from this peer
prefix-list Prefix List for filtering routes
route-map Apply route map to neighbor
route-reflector-client Configure a neighbor as Route Reflector client
send-community Send community attribute to this neighbor
unsuppress-map Route-map to selectively unsuppress suppressed
routes
weight Set default weight for routes from this neighbor
