Describes the process of configuring Resilient Hashing on the SLX devices.
Resilient Hashing is available for default VRF as well as user created VRFs. To configure Resilient Hashing on default VRF:
conf term command.
SLX# conf term SLX(config)#
resilient-hash command to configure.
SLX (config)# resilient-hash ?
Possible completions:
ecmp Resilient hash ECMP
max-path Resilient hash max path (8|16|64)
SLX (config)# resilient-hash ecmp ?
enable Enable resilient hash ECMP
SLX (config)# resilient-hash ecmp enable
max-path value.
The default max-path value is 8. You can choose to use 8, 16, or 64 paths.
SLX (config)# resilient-hash max-path 8
SLX (config)#
show ip route system-summary command.
SLX # show ip route system-summary
System Route Count: 10 Max routes: 358400 (Route limit not exceeded)
System Nexthop Count: 2 Max nexthops: 4000 (Nexthop limit not exceeded)
One Path Nexthop Count: 1 Max One Path Nexthops: 48000
RH Flowset Entries: 2816 Max 32768 (Flowset limit not exceeded)
VRF-Name: default-vrf
Route count: 0 Max routes: Not Set (Route limit not exceeded)
0 connected, 0 static, 0 OSPF, 0 BGP, 0 ISIS, 0 unnumbered, 0 EVPN Host
Resilient Hashing (Flowset Sz: 128, Max RH Paths: 8, RH Nexthops: 12)
VRF-Name: mgmt-vrf
Route count: 3 Max routes: Not Set (Route limit not exceeded)
1 connected, 1 static, 0 OSPF, 0 BGP, 0 ISIS, 0 unnumbered, 0 EVPN Host
VRF-Name: vrf2
Route count: 7 Max routes: Not Set (Route limit not exceeded)
2 connected, 2 static, 0 OSPF, 1 BGP, 0 ISIS, 0 unnumbered, 0 EVPN Host
Resilient Hashing (Flowset Sz: 128, Max RH Paths: 16, RH Nexthops: 10)
VRF-Name: vrf3
SLX #
