Describes the process of configuring Resilient Hashing on SLX devices.
Resilient Hashing is available for default VRF as well as user created VRFs. To configure Resilient Hashing on user created VRFs:
conf term command.
SLX# conf term SLX(config)#
SLX (config)# vrf vrf2
SLX (config-vrf-vrf2)# ?
Possible completions:
address-family Enter Address Family command mode
describe Display transparent command information
do Run an operational-mode command
evpn VRF EVPN config
exit Exit from current mode
help Provide help information
ip VRF specific IP commands
no Negate a command or set its defaults
pwd Display current mode path
rd Configure Route Distinguisher
resilient-hash Resilient hash
top Exit to top level and optionally run command
vpn-statistics VPN Statistics
resilient-hash command to configure.
SLX (config-vrf-vrf2)# resilient-hash ?
ecmp Resilient hash ECMP
max-path Resilient hash max path (8|16|64)
SLX (config-vrf-vrf2)# resilient-hash ecmp ?
enable Enable resilient hash ECMP
SLX (config-vrf-vrf2)# resilient-hash ecmp enable
max-path value.
The default max-path value is 8. You can choose to use 8, 16, or 64 paths.
SLX (config-vrf-vrf2)# resilient-hash max-path 8
do show run vrf <vrf-name>
command.
SLX (config-vrf-vrf2)# do show run vrf vrf2
vrf vrf2
address-family ipv4 unicast
show ip route system-summary command.
SLX (config-vrf-vrf2)# show ip route system-summary
System Route Count: 10 Max routes: 358400 (Route limit not exceeded)
System Nexthop Count: 2 Max nexthops: 4000 (Nexthop limit not exceeded)
One Path Nexthop Count: 1 Max One Path Nexthops: 48000
RH Flowset Entries: 2816 Max 32768 (Flowset limit not exceeded)
VRF-Name: default-vrf
Route count: 0 Max routes: Not Set (Route limit not exceeded)
0 connected, 0 static, 0 OSPF, 0 BGP, 0 ISIS, 0 unnumbered, 0 EVPN Host
Resilient Hashing (Flowset Sz: 128, Max RH Paths: 8, RH Nexthops: 12)
VRF-Name: mgmt-vrf
Route count: 3 Max routes: Not Set (Route limit not exceeded)
1 connected, 1 static, 0 OSPF, 0 BGP, 0 ISIS, 0 unnumbered, 0 EVPN Host
VRF-Name: vrf2
Route count: 7 Max routes: Not Set (Route limit not exceeded)
2 connected, 2 static, 0 OSPF, 1 BGP, 0 ISIS, 0 unnumbered, 0 EVPN Host
Resilient Hashing (Flowset Sz: 128, Max RH Paths: 16, RH Nexthops: 10)
VRF-Name: vrf3
