The policy-based routing feature lets you use policies (based on criteria such as access control lists (ACLs), protocols, packet size, and source and destination IP addresses) to selectively forward and route IP packets.
With policy-based routing, you define a set of classifications that, when met, cause a packet to be forwarded to a predetermined next-hop interface. With this process, the packet bypasses the normal routing path in the routing table. If your policy has multiple next hops to a destination, packets are forwarded to the first available (UP) hop. If none of the next hops in the policy is available, then packets are forwarded according to the routing table.
| Route map | ACL | TCAM action |
Permit |
Permit |
The contents of the set command of the route-map entry are applied. |
Permit |
Deny |
The packet is passed and routed normally. The contents of the set command are not applied. A "permit" rule with no result actions is programmed in TCAM, which prevents further application of the route-map ACL. No ACL actions (except counter) are applied. |
Deny |
Permit |
The packet is passed and routed normally. No set commands follow the match command of a deny route-map stanza. A "permit" rule with no result actions is programmed in TCAM, which prevents further application of the route-map ACL. No ACL actions (except counter) are applied. |
Deny |
Deny |
No TCAM entry is programmed, therefore other route-map ACL entries are compared for a match. If no match is made, the packet is forwarded normally. |
If you do not specify an ACL in a stanza, normal routing occurs. The default ACL is not used.
| System Resource | Maximum amount |
| Configurable route maps | 200 |
| Configurable stanzas | 1024 |
| Available TCAMs | 2048 |
| Configurable next-hops in a stanza | 128 |
