This section details the BGP EVPN VXLAN support for data center interconnect (DCI).
Data center Layer 2
interconnect between EVPN VXLAN and EVPN MPLS or VPLS is not supported. However, EVPN
VXLAN and VPLS can coexist on the router, although a given VLAN/BD should not be
extended into EVPN and be configured for VPLS.
The following sections address a variety of DCI interconnect scenarios.
Layer 2 and Layer 3 control-plane extension
In this scenario, VXLAN tunnels are extended by means of a border leaf instead of getting terminated. This extension is primarily the spine functionality being provided by the border leaf, except that the control and forwarding planes are extended over the WAN/core in the case of a border leaf.
Layer 2 handoff
In this scenario, VXLAN tunnels are terminated at the
border leaf, as shown in the following figure. Depending on the interconnect
technology being used between data centers extending over the WAN (such as VPLS,
VXLAN Layer 2 extension, or any other interconnect scheme), the border leaf bridges
the two domains through forwarding plane learning without any control plane
extension.
Layer 3 handoff
In the case of Layer 3, all VRFs in the data center are terminated
on the border leaf and traffic is routed towards the WAN, as shown in the following
figure. Similarly, Layer 3 traffic received from the WAN is routed and forwarded
over tunnels in the data center. Because Layer 3 routes across multiple VRFs can be
imported into a single (interconnecting) VRF, all possible VRFs in a given data
center do not have to be configured on the border leaf.
EVPN Layer 3
interconnect
In this scenario, EVPN VXLAN tunnels within the data center are
terminated on the WAN edge, as shown in the following figure. In the BGP EVPN control
plane, only Type-5 prefix routes are imported from EVPN VXLAN peers and are reoriginated
towards EVPN MPLS peers. Similarly, in the other direction, EVPN Type-5 prefix routes
are imported from EVPN MPLS peers and are reoriginated towards EVPN VXLAN peers within
the data center.
EVPN VPNv4/v6 interconnect
In this scenario, EVPN Type-5 prefix
routes from the VXLAN data center are terminated on the WAN-edge device, and are
redistributed into VPNv4/v6 address-family, as shown in the following figure.
Similarly, IPv4/v6 prefix routes imported into VRFs from VPNv4/v6 are exported into
EVPN and are advertised to EVPN VXLAN peers by means of Type-5 prefix routes.
