Follow these step to configure the default remapping priorities.
device# configure terminal
device(config)# interface ethernet 1/40
device(config-if-eth-1/40)# service-policy out policyMap1
device(config-if-eth-1/40)# service-policy in policyMap1
device(config-if-eth-1/40)# end
device# show policy-map interface ethernet 1/40
Ingress Direction :
Policy-Map policyMap1
Class class_1
matches 0 packets
Police cir 40000 cbs 5000 eir 40000 ebs 3000 conform-tc 6 exceed-tc 2 conform-dscp 61 exceed-dscp 63
Stats:
Operational cir:39856 cbs:5000 eir:39856 ebs:3000
Conform Byte:0 Exceed Byte:0 Violate Byte:0
Egress Direction :
Class class_1
matches 0 packets
Stats:
Egress policer is not supported on the SLX 9150 device. The police command affects only the CIR.device# copy running-config startup-config
device# configure terminal device(config)# interface ethernet 1/40 device(conf-if-eth-1/40)# service-policy out policyMap1 device(conf-if-eth-1/40)# service-policy in policyMap1 device(conf-if-eth-1/40)# end device# show policy-map interface ethernet 1/40 device# copy running-config startup-config
