You can use show commands to display information about egress ACL rate limiting.
Important
The egress ACL rate limiting feature is not supported on SLX 9150.You can run show commands from any level of the CLI.
device# show policy-map int e 4/1 Egress Direction : Policy-Map eACLpol Class eACL100 matches 0 packets 0 bytes Police cir 1000000000 Stats: Operational cir:1000000000 cbs:0 eir:0 ebs:0 Conform Byte:161527005348 Exceed Byte:0 Violate Byte:1904690363136
device# show running-config class-map class-map eVLAN100 match vlan 100 ! class-map eVLAN200 match vlan 200 ! class-map eBDpol match bridge-domain 100
device# show policy-map Number of policy maps : 1 Policy-map epol Bound To: Eth 3/1(out) device# show running-config policy-map policy-map epol class eVLAN100 police cir 800000000 ! class eBDpol police cir 1000000000 ! class eVLAN200 police cir 500000000 !
