Follow these steps to configure an ACL that can be used to protect against ping flood attack.
device# configure terminal
device(config)# ip access-list extended acl1 2015/04/01-13:18:15, [SSMD-1400], 2315, SW/device | Active | DCE, INFO, device, IPv4 access list acl1 is created.
device(conf-ipacl-ext)# permit icmp any any 2015/04/02-11:44:45, [SSMD-1404], 2501, SW/device | Active | DCE, INFO, device, IPv4 access list acl1 rule sequence number 10 is added.
device(conf-ipacl-ext)# end
device# show running-config ip access-list extended acl1 ip access-list extended acl1 seq 10 permit icmp any any
device# configure terminal device(config)# ip access-list extended acl1 device(conf-ipacl-ext)# permit icmp any any device(conf-ipacl-ext)# end device# show running-config ip access-list extended acl1
