This section does not apply to the
 SLX 9150
				device.
		 SLX-OS uses algorithmic and sequential sampling
				simultaneously. This combination ensures that the entire counter engine database is
				periodically delivered into the software. You can set the sequential sampling timer
				to a lower rate as the overflow is prevented by algorithmic sampling.
	 Statistics collection mechanisms
		In this implementation, statistics collection
				uses counter engines as a collection mechanisms.
		With counter engines:
		  - There are 16 on-chip counter engines with 16k packet and octet counters each.
		  - Two mini counter engines B0/B1 are dedicated to the egress queue and support 4k 64-bit entries.
		  - Each counter engine can be individually assigned to a statistics source.
		  - A statistic flow is mapped to a set of counters within one of the counting engines.
		  - A packet is mapped to a counter pair within a counter set according to the packet's disposition (drop/forward status) and color.
