Two QoS hardware profiles are provided to enable/disable support for buffer allocation. Select the lossy hardware profile to disable this feature. If you execute any PFC/Pause related commands, they will throw error messages. Select the lossless profile to enable this feature. PFC/Pause configurations can now be applied to the selected interface.
device# configure terminal
device# hardware
device(hardware)# profile qos ?
Possible completions:
lossless set qos hardware lossless profile
lossy set qos hardware lossy profile
device(hardware)# profile qos lossless
device(hardware)#
device(hardware)# exit
show qos flowcontrol stats command.
device# show qos flowcontrol stats interface eth 0/1
Interface Ethernet 0/1
TX RX
PAUSE Frames: 565856 441122
PFC Pri0 Frames: 565856 441122
PFC Pri1 Frames: 565856 441122
PFC Pri2 Frames: 565856 441122
PFC Pri3 Frames: 565856 441122
PFC Pri4 Frames: 565856 441122
PFC Pri5 Frames: 565856 441122
PFC Pri6 Frames: 565856 441122
PFC Pri7 Frames: 565856 441122
