Follow these steps to configure an MPLS QoS EXP-to-traffic class mutation map. This configuration is not supported on SLX 9150 devices.
device# configure terminal
device(config)# qos-mpls map exp-traffic-class expTcMap
device(exp-traffic-class-expTcMap)# exp 0 to traffic-class 7 drop-precedence 0 device(exp-traffic-class-expTcMap)# exp 1 to traffic-class 7 drop-precedence 1 device(exp-traffic-class-expTcMap)# exp 4 to traffic-class 7 drop-precedence 0 device(exp-traffic-class-expTcMap)# exp 5 to traffic-class 7 drop-precedence 1 device(exp-traffic-class-expTcMap)# exp 6 to traffic-class 7 drop-precedence 2 device(exp-traffic-class-expTcMap)# exp 7 to traffic-class 7 drop-precedence 3
device(exp-traffic-class-expTcMap)# end
device# show qos-mpls maps exp-traffic-class
exp-traffic-class map 'expTcMap'
Exp : 0 1 2 3 4 5 6 7
Traffic-class: 5 5 4 6 5 5 5 5
Drop-Preced : 0 1 1 1 0 2 2 1
Enabled on the following slots:
This example summarizes the commands in this procedure.
device# configure terminal device(config)# qos-mpls map exp-traffic-class expTcMap device(exp-traffic-class-expTcMap)# exp 0 to traffic-class 7 drop-precedence 0 device(exp-traffic-class-expTcMap)# exp 1 to traffic-class 7 drop-precedence 1 device(exp-traffic-class-expTcMap)# exp 4 to traffic-class 7 drop-precedence 0 device(exp-traffic-class-expTcMap)# exp 5 to traffic-class 7 drop-precedence 1 device(exp-traffic-class-expTcMap)# exp 6 to traffic-class 7 drop-precedence 2 device(exp-traffic-class-expTcMap)# exp 7 to traffic-class 7 drop-precedence 3 device(exp-traffic-class-expTcMap)# end device# show qos-mpls maps exp-traffic-class device# copy running-config startup-config
