You can increase the egress throughput rate on a Traffic Management (TM) port on 10G and 100G line cards.
On a 10G card, you can increase the rate from 300 Mbps to 13 Gbps. On a 100G card, you can increase the rate from 300 Mbps to 130 Gbps. The maximum speed supported by an interface is 130% of the default interface speed.
If you configured a breakout connector on an Ethernet interface, you can also increase the egress throughput rate on a breakout port.
This feature is supported only on devices based on the DNX chipset family. For more information, see Supported Hardware.device# configure terminal
device(config)# interface Ethernet 1/2
device(conf-if-eth-1/2)# qos port-speed-up 300000
device(conf-if-eth-1/2)# end
The following example summarizes the commands in this procedure.
device# configure terminal device(config)# interface ethernet 1/2 device(conf-if-eth-1/2)# qos port-speed-up 300000 device(conf-if-eth-1/2)# end device# copy running-config startup-config
