Follow these steps to specify the mutation map to be used on a port.
A mutation map has been configured.
device# configure terminal
device(config)# policy-map policyMap1
device(config-policymap)# interface ethernet 1/1
device(conf-if-eth-1/1)# qos dscp-mutation dscpMutMap
device(conf-if-eth-1/1)# end
device# show qos map dscp-mutation dscpMutMap Dscp-to-Dscp Mutation map 'dscpMutMap' (dscp= d1d2) d1 : d2 0 1 2 3 4 5 6 7 8 9 ------------------------------------- 0 : 11 11 11 03 11 11 11 11 11 11 1 : 11 11 11 11 11 11 11 11 11 11 2 : 11 11 11 23 24 25 26 27 28 29 3 : 30 31 32 33 34 35 36 37 38 39 4 : 40 41 42 43 44 45 46 47 48 49 5 : 50 51 52 53 54 11 11 11 11 11 6 : 11 11 11 11 Enabled on the following interfaces: Eth 1/1
The following example summarizes the commands in this procedure.
device# configure terminal device(config)# policy-map policyMap1 device(config-policymap)# interface ethernet 1/1 device(conf-if-eth-1/1)# qos dscp-mutation dscpMutMap device(conf-if-eth-1/1)# end device# show qos map dscp-mutation dscpMutMap device# copy running-config startup-config
