Configure the Traffic Manager (TM) CPU port shaper rate (all towers) to the line card (LC) CPU.
device# configure terminal
device(config)# qos cpu slot 0 port shaper rate 4000 burst 1
device(config)# exit
device# show run qos cpu qos cpu slot 0 port shaper rate 4000 burst 1
device# configure terminal device(config)# qos cpu slot 0 port shaper rate 4000 burst 1 device(config)# exit device# show run qos cpu device# copy running-config startup-config
